In an attempt to fix a leaky pump (see my other thread), I've run into an issue.
I took the pump off and replaced the main wearable parts that come in the kit. I did not remove the large c-clip that relates the timing, as I understand it. Basically the front seal, head o-ring, miscellaneous o-rings and gasket on the top cover etc.. I also replaced the small filter in the inlet towards the rear. I kept things clean and felt pretty good about getting it all back together. I bled the fuel filter, bled the pump. No problems there at all. The pump must be building pressure because its squirting out of the little bleed bolt on the side of the pump very well. Fuel runs through the top "line" (rubber hose) and back into the fuel tank while cranking.
The problem is that I cannot get fuel to come out of the injector lines at all.
Any experts out there seen this as a common problem when going back together with these little pumps? I'm just at a bit of a loss on this one. [/list]
