Hello, I have just purchased a 620 with a Sherman forklift mounted on the rear. The machine had not run in the last ten years but started and ran nicely with little work. The Sherman steering box is beyond repair and I am looking for a replacement. One rear tire was flat and a considerable amount of oil has leaked from the rear axel. When I removed the wheel and break drum I found I have about an 1/8" of play. I have looked at the ford service manual and it looks like I would need a lot of special tooling to remove the bearing. Has any one replaced the bearing with normal sop tools? Thanks
