gears
So I've got 17hrs on my freshly rebuilt 158 3 cyl gas 1968 3400.
Should I pull the valve cover and retorque the head and re-adjust the valves? Is there a prescribed time to do this after break-in?
Shop Manual states "see operators manual" which says 150hr oil change, and 600 valve clearance check.
As this is a fresh motor (pistons/rings/valves/bearings/) I would think a more frequent oil/filter change (did it at 1/2 hr after initial break-in) and a re-torque/clearance wouldn't be inappropriate at this time.
Opinions/suggestions?
