600 vs 800 rear axle ratio
markct
I have been wondering if the 800
tractors had lower gears to make up for
the larger tires. I have an 800 rear end
on a 600 tractor and it's seems slightly
slower so it got me wondering
Havent actually counted teeth, but here is a chart from a manual that seems to support your hypothesis of different ratios.
Jeff
Interesting, so it would seem that even
with the larger tires the overall speeds
are slower on those tractors, thus a
lower rear end for sure. I have the
smaller 600 size tires on it so it's
definitely slowed down a fair bit.
Looking at Machnegative's "ground and engine speeds", I would think the point of comparison is direct drive forward, in other words, what is the ground speed in high gear.
Model 640 is 13.67 MPH, model 650/660 are 14.73 and model 850/860 are 14.10.
I don't know what the original tire sizes were, but to me it appears that the 650/660 had the same ring and pinion as the 640, just larger tires. Then the 850/860 either had shorter tires or lower gearing.
Got to looking at the same page in the 600/800 manual as above in the 2000/4000 manual and found the same info on rear end ratios. Just a little lower ratio in the 800 series.
This may or may not be helpful but an observation. I have both a 2600 and 4100, both 1978. Despite having smaller tires, the 2600 is way faster.
word of caution: don't get too hung up on ground speed. I have two virtually identical 8Ns and one always travels faster than two. Identical tires, even brand/age, identical transmission and differential gears.......reason is that governors do not govern tho same speeds. On later tractors, all optional transmissions do not have identical gearing, either.
