Ok stupid question: Are the cylinders 1234 front the front of the tractor on a 172 Disel ? The IT manual does not show the cylinders . Also the
manual says to adjust the valves with the engine running, is that correct? How about the PTO shaft? It seems I read somewhere that you
should put the PTO in gear before you pull the shaft. As always I appreciate your help.
Thanks,
ed1
Thanks,
ed1
