Does anyone have a brief explanation on how to fix a leak in the power steering line (from pump to valve/steering column) on a Ford 3000? I have a pin hole leak at the elbow where the line turns down toward the pump.
It appears to have been soldered at some point and that's now failing. I was thinking maybe cut the elbow out and replace with some kind of 45 degree fitting....have to use/rent a flare tool (which I have not experience with).
Any help is appreciated.
