1900 lift problem
testanley
Neighbor has a 1900 with a lift problem. Works slow but OK when you first crank the engine, after using 20-30 minutes, will no longer lift. Turn engine off, let it set for 5 minutes, crank engine and lift will again work for 20-30 minutes. Hydraulic fluid level is good. Anyone have suggestions before we tear into this?
