Need venturi for Tsx813 or Tsx769 (Ford 172)
gdschafer
New User
I am trying to locate a venturi for the Marvel Schebler carburetor on my Ford 172 industrial. Unfortunately the I.D. tag is missing so I am not sure which model my carburetor is, but from what I have read, the 172 came with either the 813 or 769. I see one listed on Mcdonalds that will fit the 769 but I do not see any listed for the 813, anyone know if they would be the same? Or is there a sure fire way of identifying my carb without the tag?
can't answer your question, but this might help your search:
awhtx
Tractor Expert
PostPosted: Mon Sep 28, 2009 4:50 pm Post subject: Re: HELP...need pic. of an M/S TSX 813 carb. Reply to specific post Reply with quote
The TSX 813 was used on the late 801/901 (change over around SN 125000) and the 4 cylinder 4000. The early 801/901 used a TSX 662 or 769. The 662/769 mounting studs were spaced on 2-11/16" centers, the 813 studs were spaced 2-3/4". The stem (hollow bolt) on the 662/769 was 3/8" and the 813 was 7/16". The fuel line from the tank to the sediment bowl on the 662/769 was 1/4", the 813 had a 5/16" fuel line. The fuel shutoff valve was the screw type on the 662/769, the 813 had a lever operated shutoff. The 662/769 was used with the 310076 manifold, the 813 got a new manifold- B9NN9425A. The 662, 769 & 813 all have the load adjusting screw on the bottom of the bowl.
http://forums.yesterdaystractors.com/viewtopic.php?t=1179637
Okay well the mounting studs on mine seem to be 2-3/4 so looks like I have the 813, that helps. When looking at the venturis on Mcdonalds and carbs unlimited, they list them by size of throttle bore, I am just wondering where exactly that is measured? Just below the flange that bolts to the manifold? Or midway down the carb? Mine measures 1-5/16" just below the manifold but widens to 1-3/8" closer to the fuel bowl.
(quoted from post at 09:52:13 11/23/16)
am not certain where the maker measured the throttle bore, but logic tells me that it should be measures where the throttle valve sits. I believe your 813 needs the 46-A247 venturi. Click on the blue number 46-247A for more details. Does you throttle bore fall within this range?
for TSX carbs with 1 3/16 & 1 5/16 throttle bore -actual size 31/32 tall / 1 1/4 wide at bottom / 1 3/8 wide at top / 15/16 ID
Product Application:
Applications: fits JD 420 430 and others 46-A247 46-A12 fits TSX-641 TSX-662 TSX-688 TSX-769 TSX-713 TSX-732 TSX-738 TSX-756 TSX-788 TSX-791 TSX-806 TSX-813 TSX-819 TSX-933 TSX-966 TSX-977 TSX-999
(quoted from post at 08:50:12 11/23/16)
That is the one I was leaning towards, but I was not sure on what the inner diameter of the venturi should be, or if it is even that critical.
(quoted from post at 09:11:04 11/23/16)
Whoops missed where it said that it actually fit the 813 model, I will give that one a shot, thank you very much for your help!
