ford 4000 hydraulic pump
(quoted from post at 15:24:36 11/22/16) It helps if you tell us if 4 cyl or 3 cyl. Lot of difference between the models.
it's a 3cyl it's a uk one didn't know or never seen a 4 cyl one
Lift cover stays on. Will have to move snap ring down out of groove then push short tube up into flow control valve. PTO line will come with pump then disconnect.
