641 3 Point Hitch
mooboy
I have a 641 that I use to sickle mow hay with. The sickle mower is 3PH mounted. After working a while and the oil is all hot the 3PH won't always lift the mower. Sometimes I can get it to lift by working the quadrant back and forth and other time I partially flip the draft lever under the seat to get it to lift. Without the mower on is always works. So do I have an internal leak?, relief valve problem? I do have a lift kit but never installed it. I can't find good instructions on how to do that.
(quoted from post at 16:40:52 11/15/16) I have a 641 that I use to sickle mow hay with. The sickle mower is 3PH mounted. After working a while and the oil is all hot the 3PH won't always lift the mower. Sometimes I can get it to lift by working the quadrant back and forth and other time I partially flip the draft lever under the seat to get it to lift. Without the mower on is always works. So do I have an internal leak?, relief valve problem? I do have a lift kit but never installed it. I can't find good instructions on how to do that.
search around here there are lots of posts on rehabbing your lift. get a manual if you dont have one. i bet a careful re-seal and linkage adjustment of your lift will do the trick.
