ford 5000 gas
cdv
got a nice 5000 gas today runs great,,for some reason it has a electric fuel pump ,,for the zenith carb, I wonder for what reason and should I do away with it will the tractor still get gas the it thanks cdv
Those tractors need a fuel pump to operate properly. You can piddle around with them on gravity flow but they won't make full hp that way.
OEM fuel lines and pump were rather circuitous and had several filters in the system. Worked good tho. Probably someone was too much of a hurry to fix it so they just stuck that electric pump in.
Easy.
My 4000 was gravity flow when I bought it and didnt make the hp I expected. I put an electric pump in it for now. Runs good. I have all the oem lines, etc for one and will put it back to original one of these days.
