Jubilee broken exhaust valve springs
matthies
Have a tractor in the shop and found two broken springs, common or just showing age? Going to try and replace the springs while head is on the tractor. thanks chris
Springs probably cracked and broke at rust spots caused by moisture/condensation/acid/sludge in the valve cover area.
I'd take a close look at them, and at the others to see if there's rust on them. Typically common valve springs don't cost much, dunno about these, probably wouldn't hurt to replace 'em all.
