I'm in the proccess of replacing the governor on a '59 651. I took the timing gear cover off but I can't get it out past the end of the crankshaft.
The manual says to remove the governor lever linkage but it is put together with a roll pin rather than a retaining screw and I don't see how to remove it.
Any advice how to get the cover out without disassembling the entire front end?
