Using my '55 Ford 861 to mow some very heavy brush. Had an old 5ft. bush hog on with a stump jumper. In a few areas I would raise the mower and back in,then lower it and cut the brush in 2nd or 3rd gear. After about an hour the lift stopped working. It will not go up at all. I checked fluid level on dipstick by 3 point lever but it says to check with lift all the way up. Never had any problems with the lift in the last 3 years that I've owned it. Anyone have any easy things to check first? Any harm in adding hydraulic fluid to see if it makes a difference?
Thanks,
Gary
Thanks,
Gary
