ford 3000 hydraulic
dennis8n
New User
drain hyd oil .replace with 134d .now nothing works dont have manul .what i think lost prime late 70s 3000
don't think 3000s were made in the late 70s.
Despite that, find the bleed plug if it has one. Also make sure you've got everything back together properly.
Get a hose adapter with pipe thread to fit the bleed plug and run a hose to the fill hole on the rear axle housing. Just let it idle till the air works out. Could take a while.
was told it was from the late 70s ill fine out going to buy a manaul. now just have to fine bleeder plug
