861 Ford Starter
DLM
What is the best way change the insulated brushes where they hook to the fields. Are they crimped and solder or spot welded?
I don't know how you can get enough heat in there to get them lose with out messing up the fields
Any one have any ideas Thanks Don
Typically they are spot welded at the factory. You just cut off the worn
out brush lead and solder on the new one.
