I checked on a Ford 4000 gas tractor for a friend. The battery keeps going down. I started by charging the battery and then load tested it and it tested fine. The charge light in the dash goes off after starting the engine. But when I removed the positive battery cable from the battery while running, the engine quit. Doesn't this indicate a charge is not getting to the electrical system? But with the charging light going off after startup, it seems the generator is working. So next step, i ran a jumper wire from the generator directly to the starter solenoid (where the charge wire is also attached), and now the engine keeps running when the positive cable is removed. I'm wondering if there is a wiring connection loss somewhere between the generator and solenoid. I don't have access to an electrical manual.
I'd appreciate any help. Thank you.
