'84 1710 leaking hyd fluid at the pump and priority valve connection. I have read a lot about the issue on this forum and others. I have contacted several NH dealers in search of the $300+ solution (SBA340060180, Priority valve hose kit). One dealer confirmed with the manufacturer that there is a four month (estimated) lead time for this kit as it is on backorder.
Does anyone have any other solution ideas for a permanent fix to this issue.
Ones found are, replace the O rings, tightening the priority pump mount bolts, elongating the mount holes and move the priority valve up for a tighter fitment.
Other ideas or options?
Thanks,
rockaukum
Thanks,
rockaukum
