Farming with my Fords
Destroked 450
Location
Harned, Ky
Mowing with the 5000 and Kuhn disc mower back in the spring
6610 with my NH BR7070 baler
4000 with the 601 mounted picker I dug out of a barn after being there over thirty years, gravity beds on a Oliver running gear.
Used the 4000SU to haul the corn to the shed
Used the 881 with box blade to level bedding in the poultry barns just to give it a little exercise, other wise it's retired.
No pic of the 4500 that's in the shop getting a Farm Hand loader conversion and all weather cab installed for winter live stock feeding. The loader was all busted up and patch welded, with my Posi Track RC85 skid loader to do the heavy loader work, I didn't need a heavy loader weighing down the front off the 4500. Adding three point hitch and lower draw bar makes it a good tractor for moving and feeding round bales.
One of the small stock ponds that dried up this year so I used the skid loader to clean it out
Nice tractors all, especially like the picker. Very sharp! Didn't look like the husking bed version. Seems to pick clean enough though.
(quoted from post at 18:38:25 10/20/16) Nice tractors all, especially like the picker. Very sharp! Didn't look like the husking bed version. Seems to pick clean enough though.
Thanks!
Picker just has a cross conveyor, my old one has a husking bed that I could swap onto this one but probably wont.
I don't shell the corn, I grind cob and all for my beef cattle so a little shuck and fodder is just added filler.
Destroked 450= I'm just curious? Was the next to the last pic of the hundred series ford
with the exhaust and intake up so high, for dring in deep water????
Hey, thanks so much for the pictures of your working Fords. I wish more people posted pictures of
Fords doing what they were built to do.
450, is the Kuhn disc mower pictured with your 5000 just a mower, or is it a mower/conditioner?
Also, what is the width of cut?
Thanks, Dave
PS: Nice looking fleet
It's a Kuhn GMD2850TL trailed disc mower, no conditioner with 8ft 10in cut, it's rated for 40 hp. I've pulled it with my 52hp 4000 and it handled it just fine but I feel on a smaller 3000 chassis the weight of the mower could become a issue on hilly ground.
Thanks for the reply!
I noticed, also, that the 5000 got a wheel upgrade!
Same wheels as on my 5610, which was originally on 7.50x18 and 15.5x38, but I did a swap with the original owner for the rears, and purchased 16" wheels for the fronts.
(quoted from post at 14:32:18 10/21/16) Thanks for the reply!
When I got the tractor it had the 7.50x16 fronts already on it with 15.5x38 power adjust on the rear, but the back rims where rusted so bad half the bead was about to break off. I got the 18.4x30's from my nephew when he took them off of a 7200 he'd bought and put on the correct 18.4x34's, not sure what I'm going to do with the 38's yet, tires are good but rims will need a lot of work. My MIL's 5600 is on 38's and will need tires in a few years so there is that option.
(quoted from post at 16:10:14 10/21/16)
How big is that Kuhn?
Cut width is 8' 10" it weighs a little over 2500lbs
My 4000 handled it fine never lugging down, no problem pulling or stopping, on my ground I mow in 6th gear at around 6.5 mph and when making turns at the end of the field the mower wanted to push the front of the tractor into the uncut grass sliding the front tires as I was straightening out.
With the 5000's heavier four cylinder engine and front axle this wasn't a issue but a tractor with the lighter swept back axle like my SU or a 3000 it could be a big issue that would force one to slow down to make turns or mow in a lower gear.
I mow hay on 4 small farms totaling 120 acres of hay, dropping from sixth gear to fifth would take another half day or more to finish mowing.
(quoted from post at 13:42:29 10/21/16)
Ha! I should have read all of the posts before submitting mine. That explains it. The only trailed disc mower that I have ever seen was in the mid-west while traveling. Here in the East if it is trailed it is almost always a Moco.
I've had a Claas WM30 8ft trailed drum mower for years and still use it, but their not made any more, I've run a couple of mounted disc mowers and hated everything about them so I was determined to get another trailed mower I could use with my 4000.
I went to the Farm Machinery Show in Louisville, Ky and looked at every mower there. Several companies now make a trailed mower based off of their 10ft mower/conditioners that need a 65+hp tractor to operate.
Only Kuhn and Vermeer make a smaller 9ft model for tractors like mine, local JD dealer sells Kuhn, nearest Vermeer dealer is 45 miles away so I bought the Kuhn, price was the same and is close to what a 8ft mounted disc mower on a caddy would cost.
I also like the gyro tongue on the Kuhn, it lets you turn 90+ degrees in both directions, most other brands allow sharp right turns but not much more than 60 degree left turns, even less in transport mode.
I have the 15.5 x 38's on mine with cast centers and spinouts, want to go wider but not higher or lower, so will change out to 30's or 34's.
The deal fell through for the 18.4 x 34's I was looking at.
18.4x30s will be a tad shorter than your 15.5x38s and 18.4x34s a tad taller. I'm guessing that 16.9x34s are going to be the closest to 15.5x38s in height. After researching, I found that the 15.5x38s had the same rolling circumference as the 16.9x34s.
HTH, Dave
Kind of like goldilocks and the three bears, one too short, one too tall, maybe one just right.
I appreciate all the help.
I'm running 7.50x16s & 18.4x30s on my '82 5610, and 7.50x18s & 15.5x38s on my '89 5610-2. Both tractors look to sit level, but the 10-2 is about 1" taller. I guess to think either was weird would kinda be nit picking! When I bought the 5610 it had 16.9x38s on it, and the seller wanted to keep them for his replacement tractor. I thought they were too much tire, so I was willing to swap for the 18.4x30s that were on his replacement tractor, an '85 5610 with cab.
Great post.
Makes me glad to hang around with this
bunch that is into this stuff.
Nice to see small scale harvesting
equipment being kept up.
Lots of tillage equipment around yet but
harvesting is a big part of a crop too.
Good solid level ground is the trick to mounting a 601.
This one when on super easy because it was in a shed with a concrete floor, working with a 601 for over 50 years also helps a little.
