146robinson
Got a 80 model 7700. I whent on vacation and my guys ran the hydralic fluid low while baling hay (One set of remote plugins some times does not work correctly and the lines pop off causing lots of fluid to shoot out) fluid was topped off with the cheap Wal-Mart tractor hydraulic fluid. Ever since then the hydralics on three point and on the loader ( the loader runs to the back and plugs into the remote not power beyond). Hydraulics only get slugish after warming up when the tractor is first started all seems to work fine. Dual power seems to work fine all the time. When our kuhn 700g11 is hooked up to the three point after hours of cutting to bring the three point up the rpms most be reved way up and also to folde it up the bailer door is slow to replaced the filter. Pump bad? Pick up screen? Wrong hydralic fluid?
