Hi all,
While rebuilding the engine on my 1973 4000 with a T4 block, I replaced the oil pump I was advised to replace the drive gear and shaft as it showed significant wear.
My tractor has a dynamo so the old drive gear has a blank top with a spacer plate and core plug above it. The new gear is a later style for 600 or 10 series which drives the tachometer.
I have been told the later type gear is the correct replacement - so do I leave the spacer out and put the core plug back in on top of the gear? Has anyone experienced this before?
Thanks,
Dave
Thanks,
Dave
