4600SU injector pump install and timing
Just had this CAV pump rebuilt and now need to reinstall it on this 1979 4600 SU three cylinder. What do I need to know/do to get it timed right?
Just make sure the gear pin enters the groove cut into the drive hub, if not correct when the three gear bolts are drawn tight flat face of hub will push the pin back, have seen this done on a Perkins with the same drive. Then set the flange mark as mentioned to "O", or where it was before removal.
