600 Ford Distributor
RDobbs
I only use my 600 about 3 or 4 times per year, and I usually
have to clean the points every time. It stays in the dry too.
Are there any cure for having to do this each time, or can
you convert it to maybe an HEI dist< Thanks
This site sells pertronix kits to replace the points. Go to tractor parts then look under your model and you will find them.
With that small a use why don't you slip a piece of thin plastic between the points. When you go to use just pull it out. I have an 8N Ford and do the same thing.
