jetlag1946
I was wondering if I could get some tips mostly on getting the cylinder drained and removed and getting the piston out . I have done this several times and tried different ways but all seemed like the hard way to do it . I have seem video of man chaining cylinder to a tree and pull piston out with a truck . I have done that except with a come along . One question is , if I have the cylinder vertical on the tractor and fully extended and remove the bottom hose will it get enough air in the port for the oil to drain out the bottom ? I want to do that before removing from tractor .
