Danny Prosser
Morning my friends I hope all is well with you today. Got a question about a replacement fuel tank for my 600. The replacement tank has both the place for the original hookup in the middle or the side hook up which I'm going to use because mine is already like that. How would I go about plugging the other hole and not worrying about leaks? I figure just a pipe plug but what would you guys put on for sealant? I have 3 tractors and they are all down when I need them the most. I'm moving dirt from where I had my pond dug out. First back In the summer my MF 230 oil pump went out and spun a rod bearing. I said well I've got my Ford 3000 to use so I'll rebuild the MF this winter. Then the radiator bites the dust on it. I said ok I'm still alright the 600 has the loader on it and I'm using it most now anyway. The rust in the fuel tank got so bad it will run for 5 minutes and stop everything up. That saying comes to mind If it weren't for bad luck. So ordered the fuel tank yesterday, ordering radiator today and looking up rebuild kits. Old iron can get expensive but I love them! Thanks in advance for all of your help.
