Rear wheel options
David G
I have 15.5 x 38 rear wheels with cast spinout centers on my 6610, think they might have been off 5000.
I would like to go wider but height is real good.
What would my options be to get same height, but wider with 34 or 30 inch rims?
I believe 16.9-34 was the optional tire for 6610.
Mine has 18.4-30 but I'd like to have a little taller tire
Look at 16.9-38 since you already have 38 rims, their a little wider but not much taller
7710's came with 18.4-34
I have a buddy with set of rims for 18.3 x34, you interested in a swap for the 30" rims?
Could be, do they have tires or just rims, mine's got a set of Michelin 18.4R-30 radials with about 60-70% thread.
I do have a set of 18.4-30's on my 5000 with Armstrong tires at about 40% I'd swap, then I could move the Michelins over to the 5000.
Where you located.
18.4-30 would be a good fit. Might be slightly taller but not much. Generally that was the size applied to a utility 6610. 18.4-34 will be a lot taller but there are certainly 56 and 6610's out there with them.
Rod
Seldom do I disagree with you Rod, but the 15.5x38s are just a couple inches taller overall than the 18.4x30s, I have both on 5610s.
I really would have preferred another set of 18.4x30s on the 10-2, but ended up with a good deal for new 8 ply 15.5x38s, so stayed with the cast center spin-out 38s.
I was just winging it when I said that... I have a set of bias 13.6-38's on the 5000 and 18.4R30 Agribibs on my TS90. To the casual observer
the Bibs stand a bit taller, but they're also newer than the others.
When I looked up the specs... you are in fact correct. The static loaded radius is about an inch taller on comparable galaxy 15.5-38 compared
to 18.4-30's...
Thanks Rod, now you're gonna be disgusted all over again when I tell you all my tractors are wearing Titans! So far, no problems with them, although I did make sure they were 8 ply rated! LOL
The 18.4x30s have been on the 5610 for 12 years, loaded with Rimguard. I also have a pair of 14.9x28 6 ply Titans on my 3910, loaded with CaCl, that have been on for 14 years. The 15.5x38s, loaded with Rim Guard, have only been on the 5610-2 for a year.
Dave
Here is picture of wheels I have now, tread is 1 - 1 1/4" left
