So I did end up buying the 7710 I was looking at! Feeding hay with a heated cab is pretty nice!! I've got a couple more questions I'm hoping you guys can help me with. The book I got with the tractor is for a stage 1 and this tractor is a stage 2. On the stage 2 tractors does the oil need to be changed on the Sims injector pump? There's no level plug to check the level in it but there's a line going into the block?? I'd like to eventually put a loader on it, but was wondering how critical the loader frame is that bolts to the tractor since there's no frame along the engine? I kind of like the looks of the westendorf ta-28, but if there's a better suited loader for it I'm all ears. It is a fwa too..... thanks!
