Hello;
I am looking at purchasing a 1960 Ford 821tractor. This was the economy model with a PTO (dealer installed ?) but no hydraulics or 3 point. On the left side of the 172 gas engine, I see the plate that usually has the hyd pump connected to the crank. Is it possible to install the usual hyd pump on this tractor (or) do I need to look into front mounted hyd pump. The reason is I would like to put a loader on this unit.
Thanks,
Skip
Thanks,
Skip
