Mounting a mid mount Mower on a 7710
Dwayne F
I have the chance to get a Mid Mount Flail Mower which is currently on a 1986 5610...will this fit directly on my 7710 series II or are there going to be some hefty changes.. I don't know the make or model of the mower yet, still working on it...About the hydraulic valves, where do they come in the Cab ?...now I feel Stupid :oops:
I'm pretty sure RodinNS commented to me about "what would fit what" in what series but I can't seem to find it in my post..
I really don't know much about mid mount mowers. What I can tell you is that the 7710 has a longer chassis than the 5610 so if you have
mounting hardware that must catch the middle transmission mounts AND the front bolster mounts then you will have a problem if that framework
is not adjustable. I wouldn't think that would be a large deal to rework if you're handy with a welder and torch...
I have no idea how the mower valves would be set up but the tractor's hydraulic systems will be identical on all 4 cylinder Force II
tractors. The cab will sit higher on the 7710 so if you have frame mounted stuff protruding into the cab that may need to be reworked... but
otherwise.... anything that is mounted on a 5610 should be easier to mount on a 7710... for the simple reason there is more room to work.
Rod
Here's a pic of it in its current home. I wondered if the height from the ground would effect how it reaches the ground. Still waiting for some more
pictures before I get too serious. I'm assuming there's a tank on the other side and was hoping I could run it from my PTO....pretty [color=green:c249ebd599][b:c249ebd599]green[/b:c249ebd599][/color:c249ebd599] to all this stuff
