860 axle trumpet leak fix
Tiger Joe
Have a small drop on my 860 from the center section. Quick inspection says it's the axle trumpet to center housing.
i think this is originally a paper gasket. So I need a gasket or can I get away with the proper gasket maker? I typically use right stuff
Could be as simple as you need to tighten up some bolts. But if you do need to replace the gasket it is best to use what was there from the factory
