I've found a 1988 7710 series two tractor with fwa dual rear remotes plus the load sensing remote, non synchro 16x4, and c/h/a. Can the load monitor remote be used to raise and lower an implement or is it just for draft control? What's the best way to determine what front axle it has? I'm going to look at it next week so I don't have the sn# right off hand. I've read through the archives and read some pretty good things about this model. I have 40 beef cows so it's main jobs will be haying in the summer and when I eventually put a loader on it feeding in the winter. From what I understand the 1000 PTO shaft is separate from the 540 so I'd have to make sure that both come with it. Just wondering if there's anything particular to this model I should look for? This will be my first Ford. Thanks!
