Adding pto to 631
markct
Just noticed this site lists a pto shaft for Ford 621 and 631...seems like an oxymoron...Or is it as simple as sliding one in and you can add pto to these tractors that came without one?
It depends on what all was not installed with the pto delete.
You could remove the round cover and reach in below the main drive shaft to feel for the pto output stub shaft. Or drain the oil down and look.
If the stub shaft is there it would be a simple task to add the pto shaft, sliding collar and engage handle.
If the stub shaft is not there then all those gears, etc inside the transmission were deleted and you would need to get a different transmission to get pto.
Thanks for the info, not trying to convert anything right now it just got me wondering when I saw a replacement pto shaft listed for models that never had pto
