Hello everyone
I'm new here hope I'm posting in the right place I just bought a Ford 5000 that needs a lot of work so I will be asking a couple of questions first off the tractor runs has some white smoke so probably going to rebuild the motor I don't know if it has sleeves or been bored yet. The tractor has absolutely no power steering but the main problem right now is the Transmission jumping out of 3rd gear so I took the cover off the trans and it was full of milky oil anyway where can I get part numbers or a schematic with a parts breakdown? I have found that the shift fork for 3 and 1 is worn And the rod where the shift Fork is attached is very worn and loose question is both the shift levers supposed to be round? The high low shifter is round the other one is Square on two sides it looks like it was made that way or is it supposed to be round? Thanks for any and all input
