Ford 2000 temp sender unit location
Folks where would I find the temperature sender unit on 64 Ford 2000 4 cyl gas tractor? Looking to replace my gauges soon but can not find the location on the sender unit?
(quoted from post at 17:55:55 09/25/16)
On the side waaaay to the rear
ok evidently I'm having a "blonde moment" or just got bad eyes, does anyone have picture or diagram of location cause I'm not seeing it? Could be staring right at me but not seeing anything that looks like the replacement sender unit.
Hmmm... "sender unit"....
A '62 - '64 2000 is a 4-cylinder, and has a bulb and
line going from the right rear of the cylinder head to
the gauge.
A '65 or newer 2000 is a 3-cylinder, and has a
sending unit at the front center of the head that
plugs into the wiring harness.
Maybe this is where the confusion is coming from?
believe I've found it, between spark plug and battery tray on rear right side of cylinder head. Evidently it's been awhile since somebody bothered with it. Gonna get my fuel gauge up and running first then tackle the temp and oil pressure gauges.
Thanks folks
