jetlag1946
I sure would love to have a screw on filter on my 4500 . Every time I changed the filter I could never stop the rubber seal from leaking . I tried everything , keeping every thing clean an oil free , silicon the seal to the block overnight , silicon the seal to the metal can overnight , do the same with permatex and other things I tried . The seal always slips to the inside enough for a slow leak . I always had to make my own paper gasket instead of the rubber and problem solved . Even so it is a big pain to change the filter . I see on ebay a conversion kit for a little over 50 buck to change to a screw on filter . My question is , isn't that spring and other parts in the old filters something that lets the oil bypass the filter if it becomes clogged and restricted to prevent the engine from damage ? If so I hate to lose that protection . But on the other hand I would be more willing to change the screw on type more often and it should be ok . It seems I remember there is something like that on an auto screw on , I believe the oil pressure relief valve opens and the oil dumps into the oil filter outlet channel. But I don't know if the adapter has that .
