flail mower for a 640
MI-Bill
How large of a flail mower can a 1955 Ford 640 handle? I would like to put a 68" flail with hammer knives on it? I get the impression that t a 60" might be safer. I want the larger unit as I can get enough offset to mow around a pond? I am looking at new light to medium duty units.
Is there a particular reason you are looking for a flail mower? I bought a 72" that I used behind my 641. It did work good, but flail mowers take some power to run. I also did not like having to replace all the knives when they were worn out, was kind of a pain in the you know where.
I run a 60" Ford 904 flail on a '55 Ford 640. The tractor is under-powered to run the mower in tall or heavy grass and because the mower is quite heavy (600 lbs.) the tractor would benefit from having some added front weight. A wider mower would only be acceptable in short grass and on flat ground.
BTW, inspecting the bearings on an old flail mower is a good idea. I just discovered the main cylinder and the guide roller bearings on my 1960s-era 907 were so far worn that they're largely missing and what's still there is badly corroded! Evidently I've been squirting grease into non-existent bearings for a few years.
I run a 60" Ford 907 flail on a '55 Ford 640. The tractor is under-powered to run the mower in tall or heavy grass and because the mower is quite heavy (600 lbs.) the tractor would benefit from having some added front weight. A wider mower would only be acceptable in short grass and on flat ground.
No way.
Flail mowers require more HP than do rotary cutters.
60" is pushing it.
Dean
It depends a lot on what you're trying to mow. I have a 72 inch Mott that my 4 cylinder 4000 can handle, but in tall grass I have to drop down to first gear. If you're mowing mostly short grass you can probably get away with it.
