Ford 8000 injector pump oil
therockatmsu
New User
I had to recently replace a fuel lift pump on my 1969 ford 8000. When I removed it a clear oil cam running out. I am wondering if anyone could tell me the type of oil I would need to put back in it and where
the top/bolt to remove to put it in at? I have attached an image link to a pic of an identical pump. Any help would be appreciated.
Thank you,
Jeff Ellis
Use the same oil as you put in the crankcase and change at the same interval.
Fill plug is the large hex(about1") at the top right of your photo.
Level check plug is a 13MM hex and to the right and in line with your lift pump.
Drain plug is identical to the level plug and at the bottom front of the pump.
