3000 Carburator
testanley
I have a 3000 3 cyl gas that after setting for a few days shows symptons of flooding when the engine is first cranked. After warm up when it finaly cranks, it runs fine. I decided to rebuild the Holly carb. To my surprise, I am told there is no rebuild kit for the Holly carb. Anybody have any ideas other than buying a new carburator?
Won't run above an idle for couple of minutes after starting, black smoke at first but clears when engine begins to run free. Engine stalls if you try to open throttle before it has time to clear what appears to be excess fuel. At first I thought it to be an ignition problem but voltage seems OK.
This site sells several kits for the Holley carb. and rebuilt carbs. Below is a listing of what they have. Does your carb model number match up with any of them?
Carburetor Kit, Basic - Kit for Holley R2923-1A, 2923-2, 3012-2, 3013-2, R3012-3A, R3013-4A, 3012, R3013-4F, 2923A, R3012-3, 12R31338, R3658A carbs on 2000 3 cyl., 3000 3 cyl., 4000 3 cyl., 5000. (Part No: H102) $28.00 [Enlarge Picture]
Carburetor Kit, Basic - Kit for Holley R4119-A, R4119-1A, R7867, R8552, R3656A, R3655A, R4120, R4120-1, R6863, R7896, R8553, R3657, R4111, R4111-1A, R6852, R8554, R3210, R3658 carbs on 2000 3 cyl., 3000 3 cyl., 4000 3 cyl., 5000. (Part No: H101) $28.00 [Enlarge Picture]
Carburetor Kit, Basic - Kit for Zenith 13913, 13914, 13912 carbs used on 2000 3 cyl., 3000 3 cyl., 4000 3 cyl. (Part No: Z107) $36.00 [Enlarge Picture]
Carburetor, New - This Zenith carburetor outperforms the original carbs used on: 2600, 3000, 3400, 3600. New replacement Zenith carburetor. For 3 cylinder 175 CID engine. Replaces OEM# C7NN9510C, C9NN9510B, D3NN9510B, D6NN9510B, D8NN9510BA, D3NN9510C, D8NN9510CA. Center to center on the 2 mounting bolts is 2 1116 inches. Made in USA, 1 year warranty. (Part No: 13914) $284.24 [Enlarge Picture]
Carburetor, Rebuilt - Fits 2000, 3000 series (3000, 3400 etc), 3 CYL. - replacement for OEM R4119, R4120, R8552, R8553, LIST6863. Add $50.00 core charge to price - this charge is refundable if you send your core to us. (Part No: 1318-CARB) $164.73
Test:
Kits for your Holley carb are readily available from CNH.
Do your self a favor and buy your kit ONLY from CNH. Take your carburetor number with you when you go. Also take about $80.00.
There is more than one version of this carb and kit available. Some of the differences are not readily apparent but your carb will not work properly if you install the wrong kit.
When you overhaul it pay particular to the float adjustment and be careful bending the bracket. The carb is sensitive to float adjustment due to the accelerator pump.
Make sure that the accelerator pump works freely in its bore and is installed properly.
Also make sure that you have no vacuum leaks and that your vacuum advance is working properly.
Dean
Well, I'm no tractor expert (see previous post :) but black smoke means "incomplete combustion". Typically this means too much fuel or too little air, but I suppose it could be a timing issue or just general ignition problems. Have you done any other work on it lately that might have modified the fuel-air balance - maybe working on the distro and accidentally bumped the main needle, causing it to open or something? When was the last time the points and condenser were changed? Is the securing bolt on the distributor quadrant tight, or could the distributor have turned a bit? Could something have clogged up the air intake - collapsed filter, bird nest in the pipe, anything? How's the compression on this tractor? If it was mine, knowing what little I know, I'd first do a quick gross check to look for loose bolts, wires, etc. Then I'd probably try to monkey with the main needle a bit to see if I can get it to smooth out by adjusting the needle. After that I'd suspect the ignition system, and replace points, condenser, wires, cap, rotor, and maybe the coil. Lastly I'd think about getting an after-market carb to replace the Holley.
Good luck,
Bob
In this message you mentioned the accelerator pump moving freely
I just went to rebuilt my Holley r4119-1a and the pump didn't want to come out of the housing. I had to drill it and pull it out now he new one won't go in very easily and isn't anywhere near "free"
Any advice would be great. Thanks
[email protected]
My holley kit from this site included a replacement accellerator pump that would not fit the bore in my casting. I was able to heat the carb body up in a crock-pot soak with pinesol overnight and get everything apart. I just reused my old pump piston.
