881 - 960 parts swap?
Lynn Patrick
I want to swap the 2 lever hydraulic valve from my '59 881 original SOS w/the Selectrol Valve from my '57 960. Should I expect any problems doing that? Or maybe I should ask if it is possible? They "look" like they mount the same.
As always, thank you for your expertise!
They are a direct swap.
Any valve from 1955 to 1981 will swap.
There are some exceptions to that - I don't
know what the 6000s used and don't know what
the big tractors used - 8000, 9000, etc
used.
But 6,8,900, all 01 series, 2/4000 Priors,
2,3,4,5,7000 will all interchange.
Dealer will sell an oring kit that has all
the right sizes for not too much $
Thanks Dean. I called the area dealer & he could not find a kit w/all O-rings needed. Does anyone have a part #??
CNH sells the O rings individually.
Aftermarket kits may not have all correct O rings.
Dean
