Points setting
I have a 1952 Ford 8N with a side mount distributor. For some reason, I am not getting a spark at the spark plug. I want to check the gap on the points, but one manual says .015" and one says .025". Does anyone know which is correct? BTW, the tractor was converted to a 12 volt negative ground with alternator before I owned the tractor. Thanks.
The 0.015 is for the front mount distributor and 0.025 is for the side mount which a 1952 would be.
