perryjosh64
Folks Im still knuckle dragging my way through re-wiring my 1964 Ford 2000 gas tractor. I've got most of it done except for the alternator wiring. It's a 3 wire alternator and I've figured out the BAT wire and the and the T2 wire going to the BAT terminal on the solenoid. However in where/how do I wire in the T1 wire coming off alternator? Seen multiple different diagrams showing either a diode or light bulb in-line with T1 wire going to either the key switch or the solenoid? also seen having a resistor in the wire between coil and key switch? End goal is can anyone explain in dumb-dumb how to wire in a 3 wire alternator?
thanks
thanks
