Tires and Rims 961
Tom Bond
Found a decent 961 but the tires need replacement and possibly the rims too. Ballpark, what would all 4 tires go for?
It has PA rims that may be repairable but I may replace them too with non PA rims. Any idea what those would go for? Haven't really looked around for any yet.
Thanks!
dmbinva is correct, and add $350.00 to $500.00 if you're paying someone else to change them, depending on if you're removing the wheels yourself and taking it to them or if you take the tractor to them and have them do all of the work. If you want them to come to your property to do the work then add even more.
New 6 loop rims are in the ball park of $150 each plus shipping and tax. You will also need replacement 6 loop centers and bolts.
If I was to buy tires, tubes and rims, I would investigate Tucker Tire.
Dean
I have a couple PA rims I would like to get out of my shop.
One has had the valve stem hole repaired, the other will need
a little repair in the same area. The rest of the rims are solid.
They are currently sandblasted down to bare metal for repair.
Before winter I will repair and repaint them so I can store them
out in the barn without letting them rust.
I have the centers and clamps too if needed.
Shoot me an email if you're interested. RoyseTractors at gmail.com
Tires will depend on size and brand.
I bought one new 14.9 x 28 this year and had it mounted on
my PA rim that I carried into the store. New tube. ~$450.
I bought a pair of 11.2 x 28 tires with new tubes mounted on
my carried in rims for about the same price two years ago.
