Hello friends. I need some help. I have a 3cyl gasoline ford 2000 and my high pressure hydraulic tube keeps blowing out of the pump.
First time it did it I cut about 3/8" off the end of the tube because it looked a little boogered up.
Since then I have replaced the big hex headed fitting along with the rubber seal and the 2 small copper rings but it keeps blowing out somtimes immediatly after startup, sometime I get a few minutes out of it.
What is supposed to hold that tube in there? I see straps on the suction side but none on the high side. Is that tube supposed to be flared? Did I cut it too short?
Thanks for the help.
