BarnyardEngineering
- Location
- Rochester, NY
From time to time I get to operate a Ford 7700 with a 777 loader on it to maintain the driveway on a property my club rents.
It's kind of a pain to use the loader to backdrag gravel because it takes a very long time for it to develop down pressure. The loader responds immediately when raising, and easily lifts a bucket full of pavement millings, but once the bucket has hit the ground it takes 90 seconds to 2 minutes before it will begin to put pressure on the ground and lift the front end of the tractor.
It took so long I initially thought that the valve was set up 1-way.
Nothing moves while I wait for it to develop down pressure. It's not like it's taking up slop in the loader itself or the mounting brackets.
The hydraulic setup is kind of screwy. There's a 2-spool Gresen valve mounted to the loader, which is connected to one of the remotes on the tractor. You bungee the remote lever back and run the loader with the Gresen valve.
