53 golden jubilee
Tractor is loading up when running.stalls,when i remove air tube from oil bath air cleaner fuel in tube. drain starts back up. what can/should i do?
make sure your air cleaner is not plugged up.. if it is it will act like choke, sucking excess fuel.
When was the last time you dumped the water and mud out of the oil cup and fill it with oil?? If that is good then make sure the air cleaner tube the one going up the center has not been fill by a mud dober nest or mouse nest
