Ford 2600 Gasoline Engine Fuel lift pump location needed
ekoik
New User
Runs on starting fluid but won't start and fuel dribbles into the glass bowl after I empty it, so I guess it's the fuel pump.
But where the heck is it located? I can't see it on the right side of the motor with the hood up and don't want to start removing exhaust pipe, etc. to get at the left side of the motor until I know for sure!
Many thanks!
Yes, the fuel pump is on the top left side
of the timing cover.
But keep in mind that the pump may not be
your problem.
There are no less than 4 fuel filters on
that tractor. First one is a screen on the
top of the fuel tap in the tank.
Second is a screen in the top of the fuel
pump. Next, there is a brass filter inside
the glass bowl and lastly, there's one in
the brass fitting where the fuel line goes
into the carb.
Any or all of them could be plugged.
