901 Hydraulic tubes
John(OR)
I don't want to beat this subject to death but,I have a 901 selecto-speed do you suppose I could split behind the transmission and work from manifold end . I'm not comfortable removing trans by myself (71 yrs old) or could I work from manifold end without splitting. thanks for any info I can get.
I'm not familiar with a 901 but if it's like the 801 there is no need for a split. Just remove the manifold and run a 7'16 tap in there as deep as it will go. Screw in a piece of all thread, slip on a pipe nipple, a washer and a nut and pull it out when you tighten the nut. After about 3/4 of an inch it will be free.
Thanks sounds simple enough, when I put new one in how do I know the other end is going where it is supposed too ?
