robilmichael
Hi, my Ford 850 just recently started to run poorly, sputter, die when given any gas, and now will not start. It ran perfectly
for the last year. New points, condenser, coil, ignition switch, and when the problem occured I completely rebuilt the carb.
Plenty of gas to the carb, but plugs do not get wet. I even bought a brand new carb and still no gas from the carb to the
engine. Plenty of suction from the carb, and from the intake manifold when the carb is off. Timing was static timed at 5 deg.
BTDC. Nothing, not even wanting to start. 6 Volt system and it turns over fine. I took the valve cover off and all valve
appear to open and close properly when the engine is turned over. None are stuck open or closed. Spraying starter fluid into
the carb intake will not even begin to start the engine.
Does anyone have any suggestion of what to look for now? I am so frustrated by this problem.
Thanks.
Thanks.
