401 injectors
This message is a reply to an archived post by Dieseltech on September 11, 2014 at 04:33:48.
The original subject was "Re: 401 injectors".
Do the 9600 injectors give more than the tw 35s ?
What Bern says is spot on, pump max fuel setting is what counts most. The info I found is the 9600 uses tip 5621595, 4 holes, .35 MM size, needle lift range is .27-.47 MM. Max fuel CC is 100. On TW-35 tip is 5621828, 4 holes, .35 MM, needle lift range is .27-.32 MM, max fuel is 116 CC.
Ok thanks.
I have a 8700 with a k27 turbo. The pump is adjusted to give more fuel .
I can see there is one injector type for 8000/8600/8700/TW10/Tw15 , one for 9000/9600/9700/TW20 , and one for Tw 25/35.
Do you also have the data on the non turbo models ?
Would I be better of changing my injectors to turbo types ?
I dont pull with it ,just a little field work.
