My tractor has not run in approx 3 years.
I drained the old gas, I put 3 drops of oil in the distributor cap on the side, changed the oil and filter and antifreeze, greased it, topped off power steering etc.
Should I remove the plugs and spray anything inside the cylinders?
I removed the coil wire and turned the engine over clockwise (me facing the front of the tractor)a few times.
Would it be wise to turn it over by hand 8-10 times to get oil pressure up or oil traveling to the top of the engine?
Thanks
Thanks
